[gdal-dev] Work report of Chaitanya kumar CH (Jul 18, 2009 to Sep 8, 2009)
Chaitanya kumar CH chaitanya.ch at gmail.com
Tue Sep 22 13:00:59 EDT 2009
Frank,
Please find the attached copy of my work report for the duration of
Jul 18, 2009 to Sep 8, 2009.
http://trac.osgeo.org/gdal/wiki/MaintenanceReportsByChaitanya
I will post my next report on 24th.
Best regards,
Chaitanya kumar CH.
+91-9848167848
#3083 Tested geos configuration with various permutations.
#3112 Fixed the 'pixel validity mask' issue in TSX COSAR driver with suggestions from petar.
#906 Tested NetCDF with a reportedly problematic dataset.
#2893 Researched on the NetCDF format.
#2857 Fixed the .xsd writer for date types and also added support for precision support for decimal data types.
#2852 OGR2OGR MySQL to Shapefile Truncating Decimal Places
#2930 Cleanup Win32 Compile Warnings
#2991 Applied the patch after some coding style adjustments and test it with various datasets.
#2798 Remove ESRI style spatial indexes from Shapefile on update via OGR. Prepared a patch. Still needs some debugging and testing.
Chaitanya kumar CH
chaitanyach at gmail.com
