[Gdal-dev] Programming with GDAL in Windows XP using DEV-C++ or CodeBlocks
btaylor bryanmtaylor13 at charter.net
Wed Sep 23 01:59:11 EDT 2009
I've been trying to use/build GDAL in Windows.  I thought I'd start with the
perry-geo hillshade, aspect, and slope command line utilities and then move
into building some custom raster calculators/manipulation utilities.
However, after spending many hours across several days attempting to compile
these files under WinXP, and searching hundreds of internet links, I am
unable to successfully link to the gdal libraries and have a successful
compile.  I have tried to use pre-compiled gdal libraries and headers and
also I have tried to compile from source myself.  Lately I have installed
CodeBlocks in an attempt to circumvent DEV-C++ in case there were problems
with the compiler gui.  Again, no success, but I do get the same reference
errors as in DEV-C++ when the linker starts (see below).
Has anyone used GDAL libraries in a windows compiling environment?  I am so
tired of experimenting.  I would really like to know if someone has done
this or can do this, and specifically, how they pulled it off.  Any help
would be appreciated.  I've dabbled in programming, but my biggest weakness
is understanding the compiling/linking process and makefiles and such.  If
anyone can help or point me in the right direction I'd be grateful.  Thanks,
Bryan.
Compiler log:
-------------- Build: Debug in Hillshade ---------------
Compiling: main.cpp
In file included from
C:/gdalwin32exe141/gdalwin32-1.4.1/include/cpl_port.h:86,
                 from C:/gdalwin32exe141/gdalwin32-1.4.1/include/gdal.h:40,
                 from
C:/gdalwin32exe141/gdalwin32-1.4.1/include/gdal_priv.h:50,
                 from C:\Hillshade\Hillshade\main.cpp:27:
C:/gdalwin32exe141/gdalwin32-1.4.1/include/cpl_config.h:89: warning:
ignoring #pragma warning
Linking console executable: bin\Debug\Hillshade.exe
obj\Debug\main.o: In function `main':
C:/Hillshade/Hillshade/main.cpp:85: undefined reference to
`_GDALAllRegister'
C:/Hillshade/Hillshade/main.cpp:90: undefined reference to `_GDALOpen'
C:/Hillshade/Hillshade/main.cpp:97: undefined reference to
`GDALDataset::GetRasterBand(int)'
C:/Hillshade/Hillshade/main.cpp:107: undefined reference to
`GDALRasterBand::GetXSize()'
C:/Hillshade/Hillshade/main.cpp:108: undefined reference to
`GDALRasterBand::GetYSize()'
C:/Hillshade/Hillshade/main.cpp:116: undefined reference to
`GDALDriverManager::GetDriverByName(char const*)'
C:/Hillshade/Hillshade/main.cpp:121: undefined reference to
`GDALDriver::Create(char const*, int, int, int, GDALDataType, char**)'
C:/Hillshade/Hillshade/main.cpp:125: undefined reference to
C:/Hillshade/Hillshade/main.cpp:151: undefined reference to
`GDALRasterBand::RasterIO(GDALRWFlag, int, int, int, int, void*, int, int,
GDALDataType, int, int)'
C:/Hillshade/Hillshade/main.cpp:206: undefined reference to
collect2: ld returned 1 exit status
Process terminated with status 1 (0 minutes, 0 seconds)
10 errors, 1 warnings
View this message in context: http://n2.nabble.com/Programming-with-GDAL-in-Windows-XP-using-DEV-C-or-CodeBlocks-tp3697752p3697752.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
