[Gdal-dev] Mosaicking MOD44W landmask (318 geotiffs)
orbiter_postmuch dan0225 at sbcglobal.net
Fri Sep 25 02:49:14 EDT 2009
After nabble decides to crash, I have to post this message all again.
I tried this script to mosaick the 318 tiffs:
@echo off
:: initial version, 2005-Nov-17, matt wilkie
:: this script is public domain
if [%1]==[] (
        echo.
        echo -={ gdal_wildmerge }=- Allow gdal_merge to accept wildcards for
input files
        echo .
        echo .  gdal_wildmerge.bat [*.tif] [merge.tif] {options}
        echo .
        echo .  gdal_wildmerge c:\BM_T\MRT_download_Win\MRT\bin\318\*.tif
merge.tif -init -9999
        echo.
        goto :EOF
        :: %1 is the input wildcard mask
        :: This is inverted from normal gdal_merge usage in order to allow
other
        :: options be passed to gdal_merge
:: delayed expansion requires windows NT or later command shell
:: (it won't work on windows 9x)
        verify other 2>nul
        setlocal ENABLEDELAYEDEXPANSION
        if errorlevel 1 goto :wrong_version
:: gdal_merge won't overwrite an existing file
        if exist %2 goto :file_exists
:: Build the input file list
        set infiles=
        for %%a in (%1) do set infiles=!infiles! "%%a"
:: Here is were the actual work happens
        set gdalcmd=gdal_merge %infiles% -o "%2"
   echo %gdalcmd%
   :: IMPORTANT, if gdal_merge is not call'ed control doesn't return
        :: to the batch file
        call %gdalcmd%
        goto :EOF
:file_exists
        echo *** the output file "%2" already exists.
        goto :EOF
:wrong_version
        echo.
        echo    Sorry, this batchfile requires DELAYED EXPANSION which is
        echo    not available in this shell. See
        echo  http://www.google.com/search?q=enabledelayedexpansion
        goto :EOF
And the command line repeats this:
-={ gdal_wildmerge }=- Allow gdal_merge to accept wildcards for input files
gdal_wildmerge c:\BM_T\MRT_download_Win\MRT\bin\318\*.tif merge.tif -init
-9999
It was supposed to build a mosaic list, but it never did.
If the program does manage to mosaick the files, the next problem would be
on how to open the resulting 200000+ pixel image.
View this message in context: http://n2.nabble.com/Mosaicking-MOD44W-landmask-318-geotiffs-tp3710710p3710710.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
