[gdal-dev] Why cannot I get all fields from s57 files with method GetFieldAsString?
Chaitanya kumar CH chaitanya.ch at gmail.com
Sat Sep 26 08:51:15 EDT 2009
Randy,
You need to set the environment variable OGR_S57_OPTIONS =
"RETURN_LINKAGES=ON" for the driver to return the FSPT group
attributes.
It is described in http://www.gdal.org/ogr/drv_s57.html
2009/9/26 Randy <randyqiuxy at hotmail.com>:
> Hi list,
> Under Mr Frank and Mr Chaitanya’s guidance, I try to get every feature’s
> field(including its name and value). But I find that I cannot get all
> fields. The following is my code snippet(in MFC):
>                     CString strEnd=”\r\n”;
>                        int nFieldCount=0;
> for(nFieldCount=0;nFieldCount<poFeature->GetFieldCount();nFieldCount++)
> poFieldDefn=poFeature->GetFieldDefnRef(nFieldCount);
>                            fieldName=poFieldDefn->GetNameRef();
> fileFieldAttr.Write(fieldName,strlen(fieldName));
>     outputFieldAttr=poFeature->GetFieldAsString(nFieldCount);
> fileFieldAttr.Write(outputFieldAttr+strEnd,strlen(outputFieldAttr)+2);
> Then, what I got was as follows:
> RCID3
> PRIM1
> GRUP2
> OBJL9
> RVER1
> AGEN550
> FIDN344289455
> FIDS2233
> LNAM0226148570AF08B9
> LNAM_REFS(2:02261485702E08B9,02261485703208B9)
> FFPT_RIND(2:2,2)
> RCID4
> PRIM1
> GRUP2
> OBJL39
> It means that I didn’t get the feature’s attribute field(ATTF) like
> ATTL、ATVL and feature’s FSPT field(Feature Record to Spatial Record Pointer)
> like ORNT、USAG、MASK.
> Then who can tell me what’s wrong with my code?
> Thanks a lot!!!
> Best Regards,
> Randy.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
