Fwd: [gdal-dev] 1.7 Release Planning
Eric Domazlicky edomazlicky at gmail.com
Tue Sep 29 12:20:04 EDT 2009
 Frank and others-
I would vote for an options that adds UNIFIED_SRC_NODATA to a resulting VRT
file when using AutoCreateWarpedVRT from SWIG languages. It really is a pain
to write the code to add it manually and the NoData option is pretty much
mandatory if you are tiling from 8-bit (1 channel) raster files.
Ticket #2724 has more background on the issue. Gdal2Tiles.py also has code
that demonstrates the process of adding the required tags to the VRT file-
it's not pretty.
On Mon, Sep 21, 2009 at 7:55 AM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> Howard Butler wrote:
>> Speaking of which, are we going to release 1.7 on your birthday again?
> Howard,
> I would like to aim somewhat earlier - perhaps the end of October with
> a bit of room to slip if needed.
> Does anyone have particular features they want to see accomplished in time
> for 1.7?
> I'd like to see some sort of handling of utf-8 filenames on windows.
> I'd like to see a new PCIDSK driver based on the new PCIDSK SDK.
> I'd like to see WKT Raster in trunk.
> I'd like to see serious progress on the bug list.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090929/3df735fc/attachment.html
