[gdal-dev] Re: can ogr2ogr split polygons that cross 180 degree longitude
Hermann Peifer peifer at gmx.eu
Wed Sep 30 15:31:15 EDT 2009
Even wrote:
> The crash was due to a bug in my code in fact. I've also reworked the algorithm
> to operate on single polygons instead of multipolygons. That seems to be enough
> to avoid triggering the GEOS topology exception in the countries.shp case. So if
> you apply r17716 + r17717, it should work ok for your test case.
Works fine now. Thanks for this ogr2ogr enhancement.
Hermann
