[gdal-dev] GDAL and JAVA
zeng xiaoxxcool at 163.com
Sat Apr 3 05:43:52 EDT 2010
Sorry, I didn't get the problem. if you want to use java and gdal lib, here is a link to download
http://download.csdn.net/source/2188920
ÔÚ2010-03-31 23:28:51£¬"GongYing Hsu" <gongyinghsu at gmail.com> дµÀ£º
Thank you,but I have a problem when I do the step 7 of http://trac.osgeo.org/gdal/wiki/GdalOgrInJava
7. Compile GDAL's Java bindings
a. Run MSVC's vcvars32.bat
b. In <gdal-dir>\swig\java, edit the java.opt file pointing it to your correct JDK and ant locations.
c. In <gdal-dir>\swig, run "nmake -f makefile.vc java".
It got some error,and I took the error as a picture in the attachment.
Could you teach me how to solve it???
Thank you very much.
zeng <xiaoxxcool at 163.com> ì¶ 2010Äê3ÔÂ31ÈÕÏÂÎç11:06 Œ‘µÀ£º
if you are using windows, put all the *.dll files to $JAVA_HOME/bin/, gdal.jar to $JAVA_HOME/jre/lib/ext/, and add $JAVA_HOME/bin to your system path. It will work.
ÔÚ2010-03-31 14:25:31£¬"GongYing Hsu" <gongyinghsu at gmail.com> дµÀ£º
Excuse me!
Is there has any tutorial about GDAL for JAVA?
What I use is JDK 1.6 and gdal1.7.1. So how do I set up the GDAL for JAVA??
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100403/d902a2c1/attachment.html
