[gdal-dev] NetCDF geotransform - pixel centre/upper-left issue
Pinner, Luke Luke.Pinner at environment.gov.au
Tue Apr 6 01:32:26 EDT 2010
The NetCDF driver computes the pixel centre from lat/lon variables (see
http://trac.osgeo.org/gdal/ticket/1506).
Is this correct or should it compute pixel upper-left?
Using the example NetCDF dataset attached to the above ticket
(http://trac.osgeo.org/gdal/attachment/ticket/1506/out.nc), gdalinfo
reports the min longitude value to be -1.40625 which is not a valid
longitude (it's 1/2 a pixel less than 0 which is the min value in the
NetCDF lon variable).
gdalinfo out.nc
$ gdalinfo -nomd out.nc
Warning 1: Latitude grid not spaced evenly.
Seting projection for grid spacing is within 0.1 degrees threshold.
Driver: netCDF/Network Common Data Format
Files: out.nc
Size is 128, 64
Coordinate System is `'
Origin = (-1.406250000000000,89.258462312871046)
Pixel Size = (2.812500000000000,-2.789326947277220)
Corner Coordinates:
Upper Left  (  -1.4062500,  89.2584623)
Lower Left  (  -1.4062500, -89.2584623)
Upper Right (     358.594,      89.258)
Lower Right (     358.594,     -89.258)
Center      ( 178.5937500,   0.0000000)
Band 1 Block=128x1 Type=Float32, ColorInterp=Undefined
  NoData Value=9.96920996838686905e+36
Regards
Luke
If you have received this transmission in error please notify us immediately by return e-mail and delete all copies. If this e-mail or any attachments have been sent to you in error, that error does not constitute waiver of any confidentiality, privilege or copyright in respect of information in the e-mail or attachments.
Please consider the environment before printing this email.
