[gdal-dev] vrt removes transparent pixels?
Chaitanya kumar CH chaitanya.ch at gmail.com
Tue Apr 6 16:29:35 EDT 2010
Wendell,
Can you provide the exact commands you used?
On Wed, Apr 7, 2010 at 12:52 AM, Wendell Turner <wendell at enflight.com>wrote:
> I want to change the color palette on a gif file.  The
> instructions on the wiki here:
> http://trac.osgeo.org/gdal/wiki/FAQRaster#Howtocreateormodifyanimagecolortable
> explain how to do it:
>  gdal_translate -of VRT your.tif your.vrt
>  gdal_translate your.vrt your_fixedup.tif
> but doing this (without editing the .vrt file) changes
> transparent pixels to white.  Is there a way to use
> gdal_translate to do this and also keep transparent pixels?
> Or is that related to error message from gimp?
>  .gif: unknown field with tag 42113 (0xa481) encountered
> (gimp didn't complain about the original image)
> Thanks,
> Wendell
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100407/cefe3189/attachment.html
