[gdal-dev] getcolortable is null
weixj2003ld weixj2003ld at 163.com
Wed Apr 7 21:15:42 EDT 2010
Thk u for your detail reply.
1.Now,I have a DEM(.img) file,and its band number is 1.When I use 'gdal_translate  -b 1 -of  PNG old.img new.png' to create a png file(I think its contains height map infomation,is it?).the error 'Warning 6:PNG driver doesn't support data type Int16.Only eight bit<Byte>' and sixteen bit<Uint16> bands supported.Defaulting to Byte.
2.When I use 'gdal_translate -b 1 -of JPEG old.img new.jpg',the error 'JPEG doesn't support data type Int16. Only eight and twelve bit bands supported<Mk1 libjepg>'
happy every day.
>weixj2003ld wrote:
>> Thk u very much.
>> I have two questions.
>> 1.If I want to use the following combination,
>> Red=Band3
>> Green=Band2*0.8+band4*0.2;
>> Blue=band1
>Wei,
>This will require programming or scripting.   It cannot be done
>with the stock commandline tools.
>> 2. what is the general combination for good look jpeg file?
>That depends greatly on the source sensor and the goals of the visualization.
>A 4,2,1 b  false color band combination is common with Landsat imagery,
>butit can be disputed whether it looks good or not.  Also, constrast
>stretching is often also desirable on satellite imagery for best
>visualization.
>Best regards,
>I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush    | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100408/53f24e46/attachment.html
