[gdal-dev] getcolortable is null
Thu Apr 8 08:24:23 EDT 2010
weixj2003ld wrote:
> Thk u for your detail reply.
> 1.Now,I have a DEM(.img) file,and its band number is 1.When I use
> 'gdal_translate  -b 1 -of  PNG old.img new.png' to create a png file(I
> think its contains height map infomation,is it?).the error 'Warning
> 6:PNG driver doesn't support data type Int16.Only eight bit<Byte>' and
> sixteen bit<Uint16> bands supported.Defaulting to Byte.
Wei,
I would suggest converting to the supported type.
eg.
> 2.When I use 'gdal_translate -b 1 -of JPEG old.img new.jpg',the error
> 'JPEG doesn't support data type Int16. Only eight and twelve bit bands
> supported<Mk1 libjepg>'
Depending on your intentions, it might be appropriate to rescale the
DEM data to 8bit forvisualization purposes.
I would encourage you to spend a bit more time reading over the commandline
options documentation for gdal_translate.
Best regards,
