[gdal-dev] GDAL trunk compilation broken by r19335 / minizip / libkml
Harsh Govind harsh.govind at spadac.com
Thu Apr 8 09:03:45 EDT 2010
Oh good. Thanks a lot for enabling this driver. It has been tested for rasters over 18GB in size and gives options of both JPG/PNG with default to JPG.
Next week I will also add an auto-test to make sure the compilation is working.
Regards,
Harsh Govind
________________________________________
Sent: Thursday, April 08, 2010 05:46 AM
To: Harsh Govind
Cc: Even Rouault; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] GDAL trunk compilation broken by r19335 / minizip /     libkml
2010/4/8 Harsh Govind <harsh.govind at spadac.com<mailto:harsh.govind at spadac.com>>
I just checked the link and seems like the build is broken on szekerest-vc80-full. It cannot find ioapi.h which should be present in minizip include directory. I compiled the minizip as a library. Below are the commands I used in order to build minizip in VS2005 Command Prompt:
The issue was fixed and seems working correctly on szekerest-vc80-full.
Best regards,
Tamas
