[gdal-dev] Re: Translating from to JPEG2000 to ECW
Wickes wickestheweakestgimp at hotmail.com
Thu Apr 8 10:33:15 EDT 2010
Thanks for your reply. Your points about the cache switches make sense as
they now seem to be making a difference to the amount of memory used whereas
before they seemed to do nothing. Sadly, the conversion is still failing at
the same point as before even with the new FWTools package. I've also tried
on another machine and with another file JP2 which both fail in the same way
indicating that the fault is something generic to the JPEG2000 to ECW
process.
I've read about the 500mb limit, could this be an issue? The file is 300mb
higly compressed JP2 but as uncompressed it is well over 500mb...
View this message in context: http://n2.nabble.com/Translating-from-to-JPEG2000-to-ECW-tp4864713p4871442.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
