[gdal-dev] Support for GeoTIFF 12 bit with JPEG compression.
Even Rouault even.rouault at mines-paris.org
Sun Apr 11 04:47:36 EDT 2010
Zoltan,
GDAL supports reading & writing JPEG-IN-TIFF 12bit since version 1.7.0,
provided that you build it with internal libtiff and internal libjpeg.
See http://trac.osgeo.org/gdal/wiki/TIFF12BitJPEG
Best regards,
Even
Le Sunday 11 April 2010 09:49:54 Zoltan Szecsei, vous avez écrit :
> Hi,
> Is GDAL likely to get support for these image formats anytime soon?
> (Aerial images from the Intergraph DMC system)
> Thanks & regards,
> Zoltan
> zls at gl1:/home/gisdata$ gdalinfo 2820D_2009_151_06_0204_RGB.tif
> ERROR 1: JPEGLib:Unsupported JPEG data precision 12
> Driver: GTiff/GeoTIFF
> Files: 2820D_2009_151_06_0204_RGB.tif
> Size is 7680, 13824
> Coordinate System is `'
> Metadata:
>   TIFFTAG_XRESOLUTION=833.33331
>   TIFFTAG_YRESOLUTION=833.33331
>   TIFFTAG_MINSAMPLEVALUE=0
>   TIFFTAG_MAXSAMPLEVALUE=4095
>   TIFFTAG_RESOLUTIONUNIT=3 (pixels/cm)
> Image Structure Metadata:
>   COMPRESSION=JPEG
>   INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0,13824.0)
> Upper Right ( 7680.0,    0.0)
> Lower Right ( 7680.0,13824.0)
> Center      ( 3840.0, 6912.0)
> Band 1 Block=256x256 Type=UInt16, ColorInterp=Red
>   Overviews: 3840x6912, 1920x3456, 960x1728, 480x864, 240x432, 120x216,
> 60x108, 30x54, 15x27
> Band 2 Block=256x256 Type=UInt16, ColorInterp=Green
> Band 3 Block=256x256 Type=UInt16, ColorInterp=Blue
