AW: [gdal-dev] Re: ogr2ogr BeTA2007 grid
Even Rouault even.rouault at mines-paris.org
Wed Apr 14 16:00:07 EDT 2010
Tilo,
The EPSG database, at least as transformed in GDAL .CSV files (I can't say for
the original one) never includes grid, so if you want one grid to be used,
you can't simply specify EPSG:XXXX but you have to use the full expanded
proj.4 string with +nadgrids=   +wktext
As you noted, it is essential to add the +wktext parameter. Quoting
http://www.gdal.org/ogr/classOGRSpatialReference.html#f1a29550373c2c14bd11514641e58e7c :
"Some parameters, such as grids, recognised by PROJ.4 may not be well
understood and translated into the OGRSpatialReference  model. It is possible
to add the +wktext parameter which is a special keyword that OGR recognises
as meaning "embed the entire PROJ.4 string in the WKT and use it literally
when converting back to PROJ.4 format"."
As you, I'm also skeptical about the suggestion of the wheregroup.com PDF. As
far as I know and could test, "EPSG:31466
+nadgrids=/Daten/etrs89/./BETA2007.gsb" is just interpreted as plain
EPSG:31466 by GDAL/OGR.
Best regards,
Even
Le Wednesday 14 April 2010 15:14:16 Tilo Villwock, vous avez écrit :
> Hey that did the trick. Seems like with EPSG codes the nadgrids parameter
> is just being dropped without further notice. So it's necessary to use the
> complete proj parameters for both shape files including the nadgrids and
> wktext option to get the results right. With PROJ_DEGUB=1 I also noticed
> that it is indeed necessary to put "./" before the grid file name, as it
> otherwise looks for it in the working directory of fwtools. Anyways, cs2cs
> as well as ogr2ogr work now as expected!
> Despite that, it seems like the wheregroup.com tutorial
> (http://wheregroup.com/de/system/files/Transformation_mit_freien_Tools_Prax
>is.pdf) wasn't right after all and from what I discovered, it makes me
> wonder whether they tested their results at all or just copied from someone
> else.
> Thanks a lot anyways!
> -------- Original-Nachricht --------
> > Datum: Wed, 14 Apr 2010 13:33:58 +0200
> > Von: "Schmitz, Uwe" <uwe.schmitz at bezreg-koeln.nrw.de>
> > An: "Tilo Villwock" <tilovillwock at gmx.de>, gdal-dev at lists.osgeo.org
> > Betreff: AW: [gdal-dev] Re: ogr2ogr BeTA2007 grid
> > Tilo,
> > > > ogr2ogr -s_srs "+proj=tmerc +lat_0=0 +lon_0=9 +k=1 +y_0=0
> > > +ellps=bessel
> > > > +nadgrids=BETA2007.gsb" -t_srs EPSG:25832 target.shp source.shp
> > > I used the parameters instead, but it didn't work either. In
> > > fact, I think it doesn't matter since ogr2ogr looks up the
> > > same parameters in its EPSG file and converts the whole
> > > string to WKT anyway. So the result should be the same.
> > > Any other thoughts?
> > please try to verify that the grid is read.
> > Therefore set the environment variable
> > PROJ_DEBUG before running ogr2org, e.g. (Windows cmd):
> > set PROJ_DEBUG=1
> > Then you see if the grid is accessed at all.
> > FYI, here is my setup for transforming coordinates
> > with cs2cs from german "Gauss-Krueger stripe 3/DHDN" to
> > "UTM Zone 32N/ETRS89"):
> > cs2cs \
> >       +proj=tmerc \
> >       +lat_0=0 \
> >       +lon_0=9 \
> >       +k=1.0 \
> >       +x_0=3500000 \
> >       +y_0=0 \
> >       +ellps=bessel \
> >       +units=m \
> >       +nadgrids=BETA2007.gsb \
> >    +to \
> >       +proj=utm \
> >       +ellps=GRS80 \
> >       +towgs84=0,0,0 \
> >       +zone=32
> > Hope that helps.
> > Uwe
