[gdal-dev] gdal_translate png from geotiff resolution problem
Fri Apr 16 10:19:13 EDT 2010
achrysochoou wrote:
> Hi,
> I used this command "gdal_translate -of PNG test.tif test.png" and i got a
> 300KB PNG from a 650KB (just the image file) GEOTIFF.
> I was wondering if there is a method to extract the image from the geotiff
> or not lose data in the conversion process?
Achrysochoou,
The PNG format is compressed so you likely have not lost any image quality
in the translation process.  PNG does not inherently include coordinate system
or georeferencing though so you may well have lost this or other metadata.
Best regards,
