[gdal-dev] Re: -scale command
hjp85 henrypatton at gmail.com
Fri Apr 16 11:36:55 EDT 2010
Frank Warmerdam wrote:
> So either you need to just use -scale and let it rescale things to 0 to
> 255
> (and then perhaps rescale again to 0 to 1000), or you could run gdalinfo
> with the -mm (min max) switch to find the maximum value in advance.
Ah, ok. Thanks Frank, your first suggestion worked.
View this message in context: http://n2.nabble.com/scale-command-tp4913331p4913721.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
