[gdal-dev] Re: KyngChaos Frameworks: GDAL's numpy vs Enthought's numpy
Christopher Barker Chris.Barker at noaa.gov
Mon Apr 19 13:59:01 EDT 2010
K.-Michael Aye wrote:
> After a restart of the Terminal and start of ipython, an
> import numpy
> imports numpy 1.3.0 from the GDAL framework as confirmed by
> numpy.__version__ and numpy.__path__
Did you try _not_ doing that, and using EPD's numpy instead -- maybe
William is right, and GDAL doesn't care.
> and recommended as a remedy to
> "rebuild the GDAL Python bindings against Enthought's numpy."
Option 3:
Ask Enthought to include GDAL in EPD. Not a bad idea, there is lot's of
geo-spatial stuff to be done in the scientific programing world, though
it won't happen tomorrow, and if you're not a paying customer, you might
not have much leverage!
Good luck,
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
