[gdal-dev] Re: KyngChaos Frameworks: GDAL's numpy vs Enthought's numpy
Christopher Barker Chris.Barker at noaa.gov
Mon Apr 19 14:27:05 EDT 2010
William Kyngesburye wrote:
> If you need to use GDAL with some other python module that uses
> numpy, in the same script, or in the same session, this could still
> be a problem.
yup -- that simply won't work
> maybe importing the other module before gdal would
> work.
I don't think that will work either, unless you are right, and GDAL only
uses the Python API -- I don't think that's the case, though --don't you
need numpy to compile the GDAL bindings?
You could probably figure out a way to import both numpys separately,
and then pass arrays back and forth using array.view(), but that would
get ugly really fast!
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
