[gdal-dev] GDAL/OGR 1.7.2 Release Candidate
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Wed Apr 21 11:43:19 EDT 2010
Ari Jolma wrote:
> Frank Warmerdam wrote:
>> Folks,
>> Today I updated the news file and prepared a 1.7.2 release
>> candidate.  The
>> NEWS is available at:
>>   http://svn.osgeo.org/gdal/branches/1.7/gdal/NEWS
>> The source files are at:
>>   http://download.osgeo.org/gdal/gdal-1.7.2RC1.tar.gz
>>   http://download.osgeo.org/gdal/gdal172RC1.zip
>> I regenerated configure with a newer version of autoconf so please
>> keep an
>> eye on possible negative effects that might have had.   Testing is
>> encouraged.
>> I'll call for a vote to promote it to official release tomorrow I hope.
> On a RHEL x86_64 make dies very fast (after vanilla configure):
> /home/ajolma/gdal-1.7.2/libtool: line 152: CDPATH: command not found
> libtool: Version mismatch error.  This is libtool 2.1a, but the
> libtool: definition of this LT_INIT comes from an older release.
> libtool: You should recreate aclocal.m4 with macros from libtool 2.1a
> libtool: and run autoconf again.
> then...
> sh autogen.sh
> ./configure
> make
> no problems
> I'm no autotools guru, so can't immediately say what's the problem.
> Same problem on a ubuntu i686, except that the sh autogen.sh does not
> fix the problem but reports issues (see below)
> Ari
>> Best regards,
> ajolma at ubu:~/gdal-1.7.2$ sh autogen.sh
> + aclocal -I ./m4
> configure.in:56: warning:
> AC_CACHE_VAL(_LT_TAGVAR(lt_prog_compiler_pic_works, ), ...):
> suspicious cache-id, must contain _cv_ to be cached
> ../../lib/autoconf/general.m4:2018: AC_CACHE_VAL is expanded from...
> ../../lib/autoconf/general.m4:2039: AC_CACHE_CHECK is expanded from...
> m4/libtool.m4:1261: _LT_COMPILER_OPTION is expanded from...
> m4/libtool.m4:3377: _LT_COMPILER_PIC is expanded from...
> m4/libtool.m4:5077: _LT_LANG_C_CONFIG is expanded from...
> m4/libtool.m4:122: _LT_SETUP is expanded from...
> m4/libtool.m4:56: LT_INIT is expanded from...
> m4/libtool.m4:86: AC_PROG_LIBTOOL is expanded from...
> configure.in:56: the top level
> configure.in:56: warning: AC_CACHE_VAL(lt_prog_compiler_static_works,
> ...): suspicious cache-id, must contain _cv_ to be cached
> m4/libtool.m4:1313: _LT_LINKER_OPTION is expanded from...
> AC_CACHE_VAL(_LT_TAGVAR(lt_prog_compiler_pic_works, CXX), ...):
> m4/libtool.m4:5184: _LT_LANG_CXX_CONFIG is expanded from...
> m4/libtool.m4:771: _LT_LANG is expanded from...
> m4/libtool.m4:754: LT_LANG is expanded from...
> m4/libtool.m4:782: _LT_LANG_DEFAULT_CONFIG is expanded from...
> AC_CACHE_VAL(lt_prog_compiler_static_works_CXX, ...): suspicious
> + autoconf
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Could you try with ./configure --without-libtool ?
Peter
Dott. Peter Hopfgartner
R3 GIS Srl - GmbH
Via Johann Kravogl-Str. 2
I-39012 Meran/Merano (BZ)
Email: peter.hopfgartner at r3-gis.com
Tel. : +39 0473 494949
Fax  : +39 0473 069902
www  : http://www.r3-gis.com
XING : http://www.xing.com/go/invita/8917535
