[gdal-dev] kyngchaos Framework build doesn't support OGDI
Harsh Govind harsh.govind at spadac.com
Wed Apr 21 19:36:36 EDT 2010
I am using OGDI with 1.7.1 and everything looks good. I compile OGDI and then change nmake.opt in GDAL to point to that lib. Which version of OGDI are you compiling? Also, this is on windows.
Regards,
Harsh Govind
________________________________________
From: gdal-dev-bounces at lists.osgeo.org [gdal-dev-bounces at lists.osgeo.org] On Behalf Of Christopher Barker [Chris.Barker at noaa.gov]
Sent: Wednesday, April 21, 2010 07:29 PM
To: woklist at kyngchaos.com; gdal-dev
Subject: [gdal-dev] kyngchaos Framework build doesn't support OGDI
William,
I couldn't see a place to report this on your site, to I'm reporting it
here. The 1.7 GDAL build doesn't seem to support the OGDI drivers,
whereas the 1.6 build does.
I'm using ORG to read the VPF, as used by the NGA digital nautical
charts. Note:
$ /Library/Frameworks/GDAL.framework/Versions/1.6/Programs/ogrinfo
gltp:/vrf/Users/cbarker/Temp/DNC16/A1610880
yields:
ERROR 4: OGDI Driver doesn't support update.
Had to open data source read-only.
INFO: Open of `gltp:/vrf/Users/cbarker/Temp/DNC16/A1610880'
       using driver `OGDI' successful.
1: buildngp at cul(*)_point (Point)
2: commp at cul(*)_point (Point)
Whereas:
$ /Library/Frameworks/GDAL.framework/Versions/1.7/Programs/ogrinfo
yields:
FAILURE:
Unable to open datasource `gltp:/vrf/Users/cbarker/Temp/DNC16/A1610880'
with the following drivers.
   -> ESRI Shapefile
   -> OGDI
So OGDI is in the list, but it doesn't work.
Note that I'm having trouble getting this to work with my own build,
too, so it may be a GDAL/OGR/OGDI issue, rather than an issue with your
Framework builds.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
