[gdal-dev] Re: Compiling in Embarcadero's CBuilder
Philippe Vachon philippe at cowpig.ca
Wed Apr 21 22:02:04 EDT 2010
I've committed a fix (r19493) that will disable the use of the new GDALCopyWords implementation. The old and new implementations are functionally equivalent, but the new implementation is in some cases 5-10x faster than the old implementation. However, there is no problem with disabling it and affecting the functionality of GDAL.
For future reference, if you hit a bug in GDAL, one of the best ways to get developer attention is to file a bug report on the GDAL Trac website (http://trac.osgeo.org/gdal/newticket), but this first requires creating an OSGeo account at http://www.osgeo.org/osgeo_userid.
Cheers,
Philippe
On 2010-04-20, at 4:34 PM, jcurru wrote:
> Thanks for your answer, Philippe.
> I could make rasterio.cpp compile by making the following change (line 38):
> // For now, work around MSVC++ 6.0's broken template support. If this value
> // is not defined, the old GDALCopyWords implementation is used.
> #define USE_NEW_COPYWORDS 1
> #endif
> #undef USE_NEW_COPYWORDS // changed
> I guess gdal will use some kind of former strategie to copy bytes.
> I hope this will generate valid code.
> But you are telling me to "file a ticket on GDAL's trac
> (http://trac.osgeo.org/gdal) and assign it to me (pvachon)." Due to my poor
> english and lack of experience in this forum, I unfortunately don't know
> what you mean. Would you be so kind to explain it to me?
> Thanks again.
> View this message in context: http://n2.nabble.com/Compiling-in-Embarcadero-s-CBuilder-tp4930084p4933551.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
