[gdal-dev] how to use docs?
Lucena, Ivan ivan.lucena at pmldnet.com
Mon Apr 26 19:51:48 EDT 2010
Hi Randy,
The GDAL docs that you created with "make docs" is basically a copy of what you have on gdal.org in
html format generated by Doxygen. You can also run "make man" and "make install-man" if that helps.
Regards,
Ivan
Randy wrote:
> Hi list,
> This maybe a bad question.
> I "make docs" and "make install docs" after installing GDAL, but then
> how should I use this docs file and query functions?
> I thought Devhelp could help me but nothing appeared on devhelp.
> Best regards,
> Randy
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
