[gdal-dev] read envisat with gdal
Roger André randre at gmail.com
Tue Apr 27 12:48:00 EDT 2010
Can you make a small portion of your data available to us?  If GDAL can read
the data file, then it should be able to read this information as well.
Roger
On Fri, Apr 2, 2010 at 5:44 PM, menglong yan <yanmenglong at gmail.com> wrote:
> Hi, I want to read envisat with gdal, and I can read the data
> successfully. However I can not get the header information such as
> "FIRST_MID_LAT"(this item could be
> found with  NEST(Next ESA SAR toolbox)) with
> GDALDataset::GetMetadataItem("FIRST_MID_LAT"). I have read the souce
> code in /frmts/envisat/, and I am sure it is
> right to call this function. I turn to Anybody who once did this job
> for some advice. Thank you!
> Kind regards.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100427/4d01c4c1/attachment.html
