[gdal-dev] Question about Ticket #2706
Jean-Claude REPETTO jrepetto at free.fr
Wed Apr 28 11:24:43 EDT 2010
Le 28/04/2010 15:38, Frank Warmerdam a écrit :
> What version of libgeotiff are you using? Could you provide a listgeo
> report, or even a pointer to the file in question? The problem is fixed
> within GDAL 1.7.2 as far as I know, but at least one of the patches is
> against libgeotiff.
> Best regards,
Frank,
Thanks for your answer. I am using libgeotiff 1.2.5.
$ listgeo /tmp/test.tif
Geotiff_Information:
    Version: 1
    Key_Revision: 1.0
    Tagged_Information:
       ModelTiepointTag (2,3):
          0                0                0
          149504           5402624          0
       ModelPixelScaleTag (1,3):
          8                8                0
       End_Of_Tags.
    Keyed_Information:
       GTModelTypeGeoKey (Short,1): ModelTypeProjected
       GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
       GTCitationGeoKey (Ascii,35): "Geoportail - France metropolitaine"
       GeographicTypeGeoKey (Short,1): User-Defined
       GeogCitationGeoKey (Ascii,128): "GCS Name = Reseau geodesique
francais 1993|Datum = Reseau geodesique francais 1993|Ellipsoid = IAG
GRS 1980|Primem = Greenwich|"
       GeogGeodeticDatumGeoKey (Short,1): User-Defined
       GeogAngularUnitsGeoKey (Short,1): Angular_Degree
       GeogEllipsoidGeoKey (Short,1): User-Defined
       GeogSemiMajorAxisGeoKey (Double,1): 6378137
       GeogInvFlatteningGeoKey (Double,1): 298.257222
       GeogPrimeMeridianLongGeoKey (Double,1): 0
       ProjectedCSTypeGeoKey (Short,1): User-Defined
       ProjectionGeoKey (Short,1): User-Defined
       ProjCoordTransGeoKey (Short,1): CT_Equirectangular
       ProjLinearUnitsGeoKey (Short,1): Linear_Meter
       ProjStdParallel1GeoKey (Double,1): 46.5         <-------------
       ProjFalseEastingGeoKey (Double,1): 0
       ProjFalseNorthingGeoKey (Double,1): 0
       ProjCenterLongGeoKey (Double,1): 0
       ProjCenterLatGeoKey (Double,1): 0
       End_Of_Keys.
    End_Of_Geotiff.
Projection Method: CT_Equirectangular
    ProjCenterLatGeoKey: 0.000000 (  0d 0' 0.00"N)
    ProjCenterLongGeoKey: 0.000000 (  0d 0' 0.00"E)
    ProjFalseEastingGeoKey: 0.000000 m
    ProjFalseNorthingGeoKey: 0.000000 m
Projection Linear Units: 9001/metre (1.000000m)
The file is available at : http://dl.free.fr/jT99pb6Ct
Best regards,
Jean-Claude
