[gdal-dev] Reading GRIB2 with GDAL 1.6.3 leeds to Warning: Investigate Template 4.8 bytes 35-41
Eloi Ribeiro eloi.ribeiro at gmail.com
Fri Apr 30 06:42:28 EDT 2010
On Thu, Apr 29, 2010 at 3:35 PM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> Eloi Ribeiro wrote:
>> Hi,
>> I keep receiving this warning using GDAL (1.6.3 released 2009/11/19 on
>> Ubuntu desktop 9.10) whith GRIB2 files:
>> "Warning: Investigate Template 4.8 bytes 35-41
>> Segmentation fault"
> Eloi,
> The message comes from this part of:
> gdal/frmts/grid/degrib18/degrib/inventory.cpp
>         case GS4_STATISTIC: /* 4.8 */
>            if (InventoryParseTime (*buffer + 35 - 5, &(inv->validTime)) !=
> 0) {
>               printf ("Warning: Investigate Template 4.8 bytes 35-41\n");
>               inv->validTime = inv->refTime + inv->foreSec;
> Basically, it appears that it means there was a problem parsing
> a date in the grib file, and it is reported as a warning.
> There is no particular reason to believe it is related to the crash
> you see with some files.
> You might want to file a ticket with one of the files resulting in a
> crash for further investigation.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
Thank's for the tip Frank.
I just submitted a ticket[1].
I hope this issue can be solved.
Regards,
[1] http://trac.osgeo.org/gdal/ticket/3555
Eloi Ribeiro
GIS Analyst
39,45º -4,40º
http://eloiribeiro.wordpress.com
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100430/3d991819/attachment.html
