[gdal-dev] OGR SQL Parser/Evaluator Overhaul
Tamas Szekeres szekerest at gmail.com
Tue Aug 3 18:41:50 EDT 2010
Frank,
I've compiled and tested the code and it works reasonably well. The only
issue is the missing strcasecmp with the MSVC builds. I would support this
addition as it's pretty much extensible comparing to the previous code.
Best regards,
Tamas
2010/8/2 Frank Warmerdam <warmerdam at pobox.com>
> Tamas Szekeres wrote:
>  > Frank,
>> Where can I find the current implementation? Is that publicly available?
> Tamas,
> I have created a branch at:
>  http://svn.osgeo.org/gdal/sandbox/warmerdam/gdal-rfc28
> The swq.c file has been split into several swq files, and the code is now
> C++ instead of flat C.  The grammar is swq_parser.y.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush    | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100804/b97cebb1/attachment.html
