[gdal-dev] Re: Editing attributes with ogr causing corrupt shapefile
Tom Jeffery tjeffery at gmail.com
Wed Aug 4 12:30:14 EDT 2010
Chaitanya,
The updated file is read properly with ogrinfo.  The only difference between
ogrinfo -al between the two, besides the new field that was created, is the
extent, which looks like this:
Original file:
Extent: (1528126.013001, 45899.818172) - (1542444.478012, 61468.662925)
Updated file:
(-179769313486231570000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000.000000,
-179769313486231570000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000.000000)
That...is a really large negative number!  Any idea why it might be getting
blown up?
-Tom
Chaitanya kumar CH wrote:
> Tom,
> Can you check the destination shapefile with 'ogrinfo' and see if it
> works?
> If ogrinfo gives a valid output of the new file, check with 'ogrinfo -al'
> and compare it with the old file's output.
> ( http://www.gdal.org/ogrinfo.html )
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
View this message in context: http://osgeo-org.1803224.n2.nabble.com/gdal-dev-Editing-attributes-with-ogr-causing-corrupt-shapefile-tp5372483p5373236.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
