[gdal-dev] get back a layer objet with ogr in python
Francis Markham fmarkham at gmail.com
Thu Aug 5 03:36:55 EDT 2010
The driver and datasource are going out of scope.  The former can be fixed
by using ogr.Open instead of driver.Open The latter can be fixed by
returning it from the function.  A revised version of your code would look
like:
# import modules
from osgeo import ogr
def openShapeLine(shapefile):
   #Ouverture du shapefile avec ogr
   datasource = ogr.Open(shapefile)
   layer = datasource.GetLayer()
   return (datasource, layer)
ds, couche = openShapeLine('/data/axe.shp')
print couche.GetName()
On 5 August 2010 17:23, Ludovic Granjon <ludovic.granjon at u-bourgogne.fr>wrote:
> Hello
> I'm trying to develop with ogr in python. I'm on ubuntu 10.4 and I use gdal
> 1.7
> When I try to get back a layer object from a function, I have the following
> message when I do python monscript.py :
> "Erreur de segmentation"
> This is my code :
> # import modules
>    driver = ogr.GetDriverByName("ESRI Shapefile")
>    datasource = driver.Open(shapefile)
>    return (layer)
> If I do a "print layer.GetName()" inside the openShapeLine function,
> there's no problem ...
> Have you any idea ?
> Thanks all
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100805/0e0fc817/attachment-0001.html
