[gdal-dev] Re: SPHEROID["unretrievable - using WGS84"...
Edi.Karadumi edikaradumi at gmail.com
Thu Aug 5 10:14:15 EDT 2010
Thnx, that dids the job. Actually i was trying with gdal_translate -a_srs
"+proj=tmerc +lat_0=0 +lon_0=21 +k=1 +x_0=4500000 +y_0=0 +ellps=krass
+units=m +no_defs" input.tif output.tif and it worked too.
Another thing if i execute this command after i have created the overview
they are not in the new file. Now my problem is should i use
gdal_translate -a_srs "+proj=tmerc +lat_0=0 +lon_0=21 +k=1 +x_0=4500000
+y_0=0 +ellps=krass +units=m +no_defs" input.tif output.tif
before
gdal_translate -of GTiff -co "TILED=YES" input.tif output.tif
or the opposite
cuz i thing that the projection removes the other info of the tile
the size of the file with overview was ~240 mb and after adding the
projection went to 170mb
View this message in context: http://osgeo-org.1803224.n2.nabble.com/SPHEROID-unretrievable-using-WGS84-tp5376320p5376648.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
