[gdal-dev] Merging shapefile
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Aug 6 08:16:49 EDT 2010
Giacomo,
If you want to merge a small number of shapefiles into a single shapefile,
look at the example near the bottom of the page
http://www.gdal.org/ogr/drv_shapefile.html
http://gdal.org/ogr2ogr.html
On Fri, Aug 6, 2010 at 12:09 PM, Giacomo Piva <piva at meeo.it> wrote:
> Hi all,
> I need to merge two shapefile, is it possible with GDAL ?
> Thank you
> Giacomo
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100806/32b81ef8/attachment.html
