[gdal-dev] Help with python gdal.RasterizeLayer
Rudi von Staden rudivs at gmail.com
Sat Aug 7 09:36:46 EDT 2010
On 07/08/2010 13:29, Rudi von Staden wrote:
> Below I've included the output I'm getting (followed by my python
> script). The RasterizeLayer command should be burning the polygon onto
> the single band raster (initialized to have all cells = 255) using a
> value of 0. However, the stats show that nothing has happened, and if
> I check the resulting GTif, all cells are still 255.
Apologies. It seems I was a little hasty in checking my own output, and
I had some issues with the extents being different. It is working now,
but the statistics are not reported correctly ([255.0, 255.0, 255.0,
0.0] before and after). Do I have to set them manually, or is there some
way to recalculate them?
Rudi
