[gdal-dev] vsizip & vsigzip on Win
Joaquim Luis jluis at ualg.pt
Sun Aug 8 20:40:15 EDT 2010
Sorry for the noise. I found that the correct syntax is
gdalinfo /vsizip/c:\m_gmt_so\tmp\N37W008.hgt.zip\N37W008.hgt
and like that it works fine.
Joaquim
> Hi,
> I'm trying to access ziped files on Windows using the /vsizip but it
> fails most of times
> According to docs, this should work no?
> gdalinfo c:/vsizip/m_gmt_so/tmp/N37W008.hgt.zip/N37W008.hgt
> but it doesn't. I get
> ERROR 4: `c:/vsizip/m_gmt_so/tmp/N37W008.hgt.zip/N37W008.hgt' does not
> exist in the file system,
> and is not recognised as a supported dataset name.
> However, I'm able to make it work by using the unix pathname syntax
> gdalinfo /vsizip/m_gmt_so/tmp/N37W008.hgt.zip/N37W008.hgt
> but even this only works when I run the command from the root dir,
> that is from C:\
> If run it from any another location I get the same error message.
> Joaquim Luis
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
