[gdal-dev] Motion: Adopt RFC 29: OGR Set Ignored Fields
Peter J Halls P.Halls at york.ac.uk
Mon Aug 9 02:19:40 EDT 2010
Frank,
Frank Warmerdam wrote:
> On Fri, Aug 6, 2010 at 10:48 AM, Tamas Szekeres <szekerest at gmail.com> wrote:
>> +1
>> I assume that this feature will be utilized in the OGR sql query processor
>> and not directly in the ogr2ogr application.
> Tamas,
> ogr2ogr has a -select switch to identify desired fields
> to be copied to the output.  I imagine ogr2ogr could
> benefit from ignoring all the undesired attributes using
> this new api.
> Currently there is no logic in the OGR SQL engine to
> ignore fields not needed in the result but I can see that
> adding this would be desirable.  It would require some
> work to walk all the expression trees (for the WHERE
> and each of the column expressions) to identify the
> fields that are used in the primary and joined tables.  I
> would potentially be willing to implement this optimization.
Please correct me if I am wrong, but is not the OGR SQL engine correct at
present, ie conformant to the SQL standard, whilst this proposal would render
OGR SQL non-conformant?
For example,
SELECT * FROM tablename WHERE condition
is the most common case and is the form currently delivered by OGR;
however,
SELECT column2,column3,column7,columnn FROM tablename WHERE condition
must be the second most common.  SQL provides for the specification of columns
to return (* / all or a list) but does not, so far as I am aware, provide a
construct by which one can specify columns to be omitted from the results
(which, I suppose, would equate to * EXCEPT FOR).
Surely the goal is compliance with the standards?
Best wishes,
Peter
> Re: the TestCapability(), I'd like to see this added too.
> I think this could be done without restarting the RFC
> process.
> Best regards,
Peter J Halls, GIS Advisor, University of York
Telephone: 01904 433806     Fax: 01904 433740
Snail mail: IT Services, University of York, Heslington, York YO10 5DD
This message has the status of a private and personal communication
