[gdal-dev] How does GDAL's NetCDF driver determine the spatial reference system
James Hiebert hiebert at uvic.ca
Mon Aug 9 19:50:17 EDT 2010
Sure.  The ticket can be found here:
https://trac.osgeo.org/gdal/ticket/3715
~James
On Mon, Aug 09, 2010 at 03:13:59PM -0400, Lucena, Ivan wrote:
> James,
> Could do file a ticked and upload a sample file on http://trac.osgeo.org/gdal/ ?
> Regards,
> Ivan
> James Hiebert wrote:
> > Hi All,
> > I'm trying to use GDAL (version 1.7.2 on Gentoo built with hdf5 and netcdf
> > support) to read NetCDF files, but I'm a little unclear on how the NetCDF
> > driver attempts to determine the georeferencing.
> > The driver page here:
> > http://www.gdal.org/frmt_netcdf.html
> > states that it will attempt to read the metadata "spatial_ref" for a Well
> > Know Text definition of the spatial reference (I assume that it means that
> > it will try to use a global attribute of the NetCDF file named spatial_ref).
> > Since this would be convenient for my application, I attempted to use GDAL
> > this way without success.
> > + I added a global attribute named "spatial_ref" with the WKT definition of
> > the spatial reference system.
> > + gdalinfo on the file still reports "Coordinate System is `'"
> > + opening the file with the python bindings and calling dst.GetProjection()
> >   returns a blank string (i.e. no projection information)
> > The full listings of my spatial reference definition, the output of ncdump
> > and gdalinfo and the output from the python session are listed below.  Can
> > anyone tell me whether I'm doing something wrong, or should I not count on
> > georeferencing being supported by the NetCDF driver?
> > ~James
> > james at basalt ~ $ ncatted -a spatial_ref,global,a,c,'PROJCS["unnamed",GEOGCS["Normal Sphere
> > (r=6370997)",DATUM["unknown",SPHEROID["sphere",6370997,0]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]],PROJECTION["Polar_Stereographic"],PARAMETER["latitude_of_origin",60],PARAMETER["central_meridian",263],PARAMETER["scale_factor",1],PARAMETER["false_easting",3925000],PARAMETER["false_northing",8325000]]'
> > narccap_ecpc-20c3m-tasmin-ncep.nc narccap_ecpc-20c3m-tasmin-ncep-with-srs.nc
> > james at basalt ~ $ ncdump -h narccap_ecpc-20c3m-tasmin-ncep-with-srs.nc
> > netcdf narccap_ecpc-20c3m-tasmin-ncep-with-srs {
> > dimensions:
> > 	xc = 123 ;
> > 	yc = 104 ;
> > 	time = UNLIMITED ; // (9496 currently)
> > 	bnds = 2 ;
> > variables:
> > 	char polar_stereographic ;
> > 		polar_stereographic:grid_mapping_name =
> > "polar_stereographic" ;
> > 		polar_stereographic:longitude_of_central_meridian = 263. ;
> > 		polar_stereographic:straight_vertical_longitude_from_pole =
> > 263. ;
> > 		polar_stereographic:standard_parallel = 60. ;
> > 		polar_stereographic:TrueGridLength_Latitude = 60. ;
> > 		polar_stereographic:XGridLength_M = 50000. ;
> > 		polar_stereographic:YGridLength_M = 50000. ;
> > 		polar_stereographic:PoleOnPlane = "north" ;
> > 		polar_stereographic:false_easting = 3925000. ;
> > 		polar_stereographic:false_northing = 8325000. ;
> > 		polar_stereographic:latitude_of_projection_origin = 90. ;
> > 	double yc(yc) ;
> > 		yc:long_name = "y-coordinate of Cartesian system" ;
> > 		yc:standard_name = "projection_y_coordinate" ;
> > 		yc:axis = "Y" ;
> > 		yc:units = "m" ;
> > 	double xc(xc) ;
> > 		xc:long_name = "x-coordinate of Cartesian system" ;
> > 		xc:standard_name = "projection_x_coordinate" ;
> > 		xc:axis = "X" ;
> > 		xc:units = "m" ;
> > 	double lon(yc, xc) ;
> > 		lon:units = "degrees_east" ;
> > 		lon:long_name = "longitude" ;
> > 		lon:standard_name = "longitude" ;
> > 		lon:axis = "X" ;
> > 		lon:NX_NumPntsOnParallel = 123 ;
> > 		lon:NY_NumPntsOnMeridian = 104 ;
> > 		lon:actual_range = 211.5412f, 316.2759f ;
> > 		lon:XGridLength_M = 50000. ;
> > 		lon:YGridLength_M = 50000. ;
> > 		lon:PoleOnPlane = "north" ;
> > 	double lat(yc, xc) ;
> > 		lat:units = "degrees_north" ;
> > 		lat:long_name = "latitude" ;
> > 		lat:standard_name = "latitude" ;
> > 		lat:axis = "Y" ;
> > 		lat:NX_NumPntsOnParallel = 123 ;
> > 		lat:NY_NumPntsOnMeridian = 104 ;
> > 		lat:actual_range = 21.23807f, 67.63758f ;
> > 		lat:XGridLength_M = 50000. ;
> > 		lat:YGridLength_M = 50000. ;
> > 		lat:PoleOnPlane = "north" ;
> > // global attributes:
> > 		:history = "Mon Aug  9 13:44:50 2010: ncatted -a
> > 		spatial_ref,global,a,c,PROJCS[\"unnamed\",GEOGCS[\"Normal
> > 		Sphere
> > 		(r=6370997)\",DATUM[\"unknown\",SPHEROID[\"sphere\",6370997,0]],PRIMEM[\"Greenwich\",0],UNIT[\"degree\",0.0174532925199433]],PROJECTION[\"Polar_Stereographic\"],PARAMETER[\"latitude_of_origin\",60],PARAMETER[\"central_meridian\",263],PARAMETER[\"scale_factor\",1],PARAMETER[\"false_easting\",3925000],PARAMETER[\"false_northing\",8325000]]
> > 		narccap_ecpc-20c3m-tasmin-ncep-with-srs.nc\n",
> > 			"Fri May  8 09:34:14 2009: ncrcat
> > tasmin_ECPC_1979010106.nc tasmin_ECPC_1981010106.nc
> > tasmin_ECPC_1986010106.nc tasmin_ECPC_1991010106.nc
> > tasmin_ECPC_1996010106.nc tasmin_ECPC_2001010106.nc
> > narccap_ecpc-20c3m-tasmin-ncep.nc" ;
> > 		:nco_openmp_thread_number = 1 ;
> > 		:spatial_ref = "PROJCS[\"unnamed\",GEOGCS[\"Normal Sphere
> > (r=6370997)\",DATUM[\"unknown\",SPHEROID[\"sphere\",6370997,0]],PRIMEM[\"Greenwich\",0],UNIT[\"degree\",0.0174532925199433]],PROJECTION[\"Polar_Stereographic\"],PARAMETER[\"latitude_of_origin\",60],PARAMETER[\"central_meridian\",263],PARAMETER[\"scale_factor\",1],PARAMETER[\"false_easting\",3925000],PARAMETER[\"false_northing\",8325000]]"
> > james at basalt ~ $ gdalinfo narccap_ecpc-20c3m-tasmin-ncep-with-srs.nc
> > Driver: netCDF/Network Common Data Format
> > Files: narccap_ecpc-20c3m-tasmin-ncep-with-srs.nc
> >        narccap_ecpc-20c3m-tasmin-ncep-with-srs.nc.aux.xml
> > Size is 512, 512
> > Metadata:
> >   NC_GLOBAL#history1=Original output in GRIB 1
> >   NC_GLOBAL#history2=Contains modifications made to original data
> >   NC_GLOBAL#history=Mon Aug  9 13:44:50 2010: ncatted -a
> >   spatial_ref,global,a,c,PROJCS["unnamed",GEOGCS["Normal Sphere
> > Fri May  8 09:34:14 2009: ncrcat tasmin_ECPC_1979010106.nc
> > tasmin_ECPC_1981010106.nc tasmin_ECPC_1986010106.nc
> > tasmin_ECPC_1991010106.nc tasmin_ECPC_1996010106.nc
> > tasmin_ECPC_2001010106.nc narccap_ecpc-20c3m-tasmin-ncep.nc
> >   NC_GLOBAL#nco_openmp_thread_number=1
> >   NC_GLOBAL#spatial_ref=PROJCS["unnamed",GEOGCS["Normal Sphere
> > Subdatasets:
> >   SUBDATASET_1_NAME=NETCDF:"narccap_ecpc-20c3m-tasmin-ncep-with-srs.nc":lon
> >   SUBDATASET_1_DESC=[104x123] longitude (64-bit floating-point)
> >   SUBDATASET_2_NAME=NETCDF:"narccap_ecpc-20c3m-tasmin-ncep-with-srs.nc":lat
> >   SUBDATASET_2_DESC=[104x123] latitude (64-bit floating-point)
> >   SUBDATASET_3_NAME=NETCDF:"narccap_ecpc-20c3m-tasmin-ncep-with-srs.nc":time_bnds
> >   SUBDATASET_3_DESC=[9496x2] time_bnds (64-bit floating-point)
> >   SUBDATASET_4_NAME=NETCDF:"narccap_ecpc-20c3m-tasmin-ncep-with-srs.nc":tasmin
> >   SUBDATASET_4_DESC=[9496x104x123] air_temperature (32-bit floating-point)
> > Corner Coordinates:
> > Upper Left  (    0.0,    0.0)
> > Lower Left  (    0.0,  512.0)
> > Upper Right (  512.0,    0.0)
> > Lower Right (  512.0,  512.0)
> > Center      (  256.0,  256.0)
> > james at basalt ~ $ python
> >>>> from osgeo import gdal
> >>>> dst = gdal.Open("narccap_ecpc-20c3m-tasmin-ncep-with-srs.nc")
> >>>> dst.GetProjection()
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
