[gdal-dev] Geotiff with bands of different type
Chaitanya kumar CH chaitanya.ch at gmail.com
Tue Aug 10 05:46:06 EDT 2010
Martin,
I'm sorry. I just found out that GDALDataset::AddBand() is not supported by
most format drivers.  GeoTiff format driver doesn't support it.  Also,
having different data types for bands may confuse some applications.
If you are trying to create a mask band, refer to
http://trac.osgeo.org/gdal/wiki/rfc15_nodatabitmask
FYI, 1.5 branch is no longer supported.
On Tue, Aug 10, 2010 at 2:03 PM, Martin Raspaud <martin.raspaud at smhi.se>wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Chaitanya kumar CH skrev:
> > Martin,
> > Yes, it is possible.
> > You can specify the data type in GDALDataset::AddBand()
> Hi,
> thanks for your answer.
> Unfortunately, I get the following error:
> ERROR 6: Dataset does not support the AddBand() method
> I am using the gtiff driver.
> Or was this solved in more recent versions of gdal ? (v. 1.5.3)
> Best regards,
> Martin
> > On Tue, Aug 10, 2010 at 12:44 PM, Martin Raspaud <martin.raspaud at smhi.se
> >     Hash: SHA1
> >     Hi all,
> >     I'm using gdal/python and I would like to create geotiffs using one
> >     band of
> >     bytes and one of float32s...
> >     Is this even possible ?
> >     Thanks,
> >     Martin
> >     _______________________________________________
> >     gdal-dev mailing list
> >     gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> >     http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > Best regards,
> > Chaitanya kumar CH.
> > /tʃaɪθənjə/ /kʊmɑr/
> > +91-9494447584
> > 17.2416N 80.1426E
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.9 (GNU/Linux)
> Comment: Using GnuPG with Fedora - http://enigmail.mozdev.org/
> iQEcBAEBAgAGBQJMYQ7rAAoJEBdvyODiyJI4GREH/j1CI911HGlK8MAMRlbhAtEl
> IIeZJbI4nlP/8hpOJWCbQuK+JSV7UJVbjcud0HqeZdjX9rfi7VVxBh1zx6BONtAz
> qXIxn0/r/xz+2G4CZJyEIsL8q4w+/vGJZ+9Wz+TR/s4AtQPrEr86PcNu5YBf2jnp
> hER54NMenInoEVmxAW0MsrkuHKL5D6mPeq7WYwUTqzCVz6twYZVwyv5IaLDsDblq
> jf2pOMir4uEfgrQshik/SxBtVcdJMCIbYvfMJPYgQG+TebgWABJUaDbKxllqrNEf
> gAqXu2b7plYCNqibAMYHQTxXrI0aLO4F6Gx2A3+t7dcjsS6Qhz+Q2fY4vMlpvrw=
> =Mji/
> -----END PGP SIGNATURE-----
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100810/4b1799c9/attachment.html
