[gdal-dev] Re: [GDAL_TRANSLATE]Problem with colorimetry
Chaitanya kumar CH chaitanya.ch at gmail.com
Tue Aug 10 12:01:00 EDT 2010
Fab,
I found the problem.
There were some differences in color tables of your images. gdalbuildvrt
application from the latest GDAL version reports the issue when you try to
build the vrt file. You're advised to preprocess your rasters with other
tools, such as pct2rgb.py or "gdal_translate -expand RGB" to operate
gdalbuildvrt on RGB rasters instead.
The reason the red areas were occuring in different areas is that
gdalbuildvrt considers only the first file's color table.
On Tue, Aug 3, 2010 at 8:36 PM, Tacot <cfab13 at hotmail.fr> wrote:
> I think more about the value of data.
> http://osgeo-org.1803224.n2.nabble.com/file/n5368754/PixelRed.jpg
> But it's not always the picture on the right which pixels become red; it
> can
> be also the picture on the left.
> I have the felling it depends on the range of merging.
> http://osgeo-org.1803224.n2.nabble.com/GDAL-TRANSLATE-Problem-with-colorimetry-tp5368059p5368754.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100810/958411b8/attachment.html
