[gdal-dev] No Interlis format support after recent svn update
Even Rouault even.rouault at mines-paris.org
Wed Aug 11 13:11:59 EDT 2010
Well, interlis is listed for me with latest SVN, so I guess it must be some
detail on your side.
Did you do a full rebuild : 'make clean' and 'make' ?
In GDALmake.opt, is HAVE_XERCES set to yes ?
In the console, when compiling do you see that it goes into
ogr/ogrsf_frmts/ili ? you can cd to that directore and make clean in it, and
then retry a make from the top directory
Le mercredi 11 août 2010 17:28:48, Andreas Neumann a écrit :
> Hi,
> For some reasons, after an SVN update, I can't use the Interlis format
> anymore. ogrinfo --formats doesn't list the Interlis 1/2 formats as
> supported.
> Luckily I still have an older installation which I can use for my data
> imports, but I would like to get it working again with the SVN version.
> What could be missing? Xerces is listed as supported by the configure
> script and ili2c.jar is also present in /usr/bin or in the jvm/lib
> directory.
> Any help/ideas would be much appreciated.
> Thanks,
> Andreas
