[gdal-dev] gdal.ReprojectImage error with gdal 1.7.1
Matthieu Rigal rigal at rapideye.de
Thu Aug 12 10:11:54 EDT 2010
Hi guys,
I just upgraded my gdal version to 1.7.1 and I had a bad surprise figuring
some of my scripts were not working anymore and I could quickly figure out
where it came from : gdal.ReprojectImage is not working as it should...
I downloaded the reproject.py script from the autotest to see what is
happening with the default tests you are also conducting.
Results:
reproject_1 success
reproject_2 4143 cs, failed
When I look at the images, the byte.tif is OK, the byte_4326 has a black
border on its right. And the image I was reprojecting from 300*300 to
5000*5000 was fully black !!!
Any one has an idea where it could come from ?
It looks a bit like bad memory management... I have python 2.6.2 here
I searched on the net and on the list, I could not find any similar issue...
Regards,
Matthieu
RapidEye AG
Molkenmarkt 30
14776 Brandenburg an der Havel
Germany
Follow us on Twitter! www.twitter.com/rapideye_ag
Head Office/Sitz der Gesellschaft: Brandenburg an der Havel
Management Board/Vorstand: Wolfgang G. Biedermann
Chairman of Supervisory Board/Vorsitzender des Aufsichtsrates:
Juergen Breitkopf
Commercial Register/Handelsregister Potsdam HRB 17 796
Tax Number/Steuernummer: 048/100/00053
VAT-Ident-Number/Ust.-ID: DE 199331235
DIN EN ISO 9001 certified
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte
Informationen. Wenn Sie nicht der richtige Adressat sind oder diese
E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den
Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie
die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
The information in this e-mail is intended for the named recipients
only. It may contain privileged and confidential information. If you
have received this communication in error, any use, copying or
dissemination of its contents is strictly prohibited. Please erase all
copies of the message along with any included attachments and notify
RapidEye AG or the sender immediately by telephone at the number
indicated on this page.
