[gdal-dev] problem install gdal1.7.1 and python
    Filippo Corò
    filippo.coro at alice.it
    Fri Aug 13 03:15:02 EDT 2010
Hi List
I'd like to use GDAL 1.7.1, but I can not install the package correctly.
Until now I used GDAL 1.6.0 with python 2.6 on windows xp sp3.
trying to install GDAL 1.7.1 I followed these steps:
- Downloaded gdal171.zip
- Makegdal build makefile project under VS2008 (creating c: \
gdalwin32-1.7.1 with folders bin, date and related dll and exe)
- Setting environmental variable PATH,c: \ gdalwin32-1.7.1 \ bin
GDAL_DATA,c: \ gdalwin32-1.7.1 \ data
- Downloaded from pypi.python.org / pypi / GDAL / # usage the file
GDAL.1.7.1.tar.gz
- Unziped GDAL.1.7.1.tar.gz in C:\GDAL-1.7.1
- Launching in the  command line   C:\GDAL-1.7.1\setup.py
 From python I can not import GDAL:
this is error messagge
IDLE 2.6.3
Import from OSGeo GDAL
   File "<pyshell#0>", line 1, in <module>
     OSGeo GDAL import from
ImportError: No module named OSGeo
What's wrong?
Best Regards
Filippo Corò
