[gdal-dev] Handling Ordnance Survey Change Only Updates
Jez Walters Jez.Walters at ipl.com
Tue Aug 17 05:16:51 EDT 2010
Peter,
I may be misinterpreting it, but the GDAL documentation (http://www.gdal.org/ogr/drv_shapefile.html) suggests that shapefiles CAN be edited:
"The OGR shapefile driver supports rewriting existing shapes in a shapefile as well as deleting shapes. Deleted shapes are marked for deletion in the .dbf file, and then ignored by OGR. To actually remove them permanently (resulting in renumbering of FIDs) invoke the SQL 'REPACK <tablename>' via the datasource ExecuteSQL() method."
I was rather hoping this would be implemented via ogr2ogr - can you confirm I'm right that ogr2ogr does NOT support this?
Warm regards,
Jez
-----Original Message-----
From: pjh1 at york.ac.uk [mailto:pjh1 at york.ac.uk] On Behalf Of Peter Halls
Sent: Tuesday 17 August 2010 08:36
To: Jez Walters
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Handling Ordnance Survey Change Only Updates
Jez,
   I would be surprised if GDAL can handle OSGB MasterMap change-only updates automatically. The process defined by OS is to locate and replace
the records concerned. Because the update may change the geometry of a record, I do not believe this can be done on a shapefile in situ. Instead
the procedure would be to input the shapefile sequentially until a record to be changed is liocated, outputing the input to a new shapefile and substituting the change record for the input as appropriate, gaining a new shapefile. On completion, the new shapefile will have the correct spatial
index and bounds. Indeed, it is probably most sensible to adopt this approach to such updates regardless of the output format, as this is 'safe'
against update problems - which, in theory, could result from a problematic GML file and permits easy reversion.
Best wishes,
Peter
On Aug 16 2010, Jez Walters wrote:
>Hello fellow GDAL users!
>I need to handle Change Only Updates (COU) for the UK Ordnance Survey
>MasterMap Topography Layer, and I was wondering how to approach this.
>Both the initial and COU data are supplied as GML, and I am currently
>converting the initial data to ESRI shapefiles using ogr2ogr.  However, the
>ogr2ogr "-update" option won't update the shapefiles using the COU data -
>unless I'm missing something?
>I currently see two ways of overcoming this:
>1. Use the COU data to update the initial GML data, and then re-convert the
>merged data to ESRI shapefiles
>2. Use the COU data to directly update the ESRI shapefiles
>Obviously the second approach is more efficient, but how difficult is it to
>create, update and delete features using the GDAL python library?
>A few pointers for how to achieve this would be most welcome!  :-)
>Warm regards,
>Jez
Peter Halls, University of York GIS Advisor
Snail Mail: Computing Service, Heslington, York YO10 5DD, England
Telephone: 01904 433806   FAX: 01904 433740
This message has the status of a private & personal communication
The information transmitted is intended only for the person
or entity to which it is addressed and may contain
confidential and/or privileged material. If you are not the
addressee, any disclosure, reproduction, copying,
distribution, or other dissemination or use of this
communication is strictly prohibited. If you have received
this transmission in error please notify the sender
immediately and then delete this email.
Any representations or commitments expressed in this email
are subject to contract.
This message has been scanned for viruses and dangerous
content. However, it is essential that the recipient also
checks this message using commercially available mail
scanning and anti-virus software. IPL Information Processing
Limited accepts no liability for any loss or damage resulting
from any virus or other dangerous content in this message.
IPL Information Processing Limited is registered in England
and Wales under company registration number 1418818.
Registration took place at Cardiff on 10 May 1979. IPL
Information Processing Limited's registered office and
normal place of business is Eveleigh House, Grove Street,
Bath, BA1 5LR, United Kingdom. IPL is also registered for
Value Added Tax (VAT) under registration number GB 601 2931 83.
