[gdal-dev] Re: how to (install) use gdal libraries in python
Christopher Barker Chris.Barker at noaa.gov
Wed Aug 18 12:31:14 EDT 2010
mail2vajram wrote:
> I followed the procedure what the link provided by you, but after when i
> used the simple code
> from osgeo import gdal
> in Python (ilde)
> when i run this code  i got the following exception.........
> "Traceback (most recent call last):
>   File "C:/Python27/ff.py", line 1, in <module>
> ImportError: No module named osgeo
so it didn't get installed to your python at all.
To help you, we'll need to know what version of python you are running,
and how you installed it, and exactly what you did to try to install
GDAL and python bindings.
NOTE: last I tried the "official GDAL binaries were not up to date, and
none of the other ones I found were compatible with the python binding
eggs without tweaking things. It would be nice to have one simple way to
get GDAL libs, utilities and python bindings all installed. (with the
python.org python, version 2.5 and 2.6 -- and maybe 2.7 now)
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
