[gdal-dev] Working with USGS NED data
Dylan Beaudette dylan.beaudette at gmail.com
Wed Aug 18 21:51:03 EDT 2010
Supposing that you had the road network and USGS NED data loaded into
GRASS, you could use the v.drape command:
http://grass.itc.it/grass65/manuals/html65_user/v.drape.html
You may be able to automate this, by looping over counties,
downloading the minimum NED required, running v.drape, and then saving
the result.
Alternatively, you could craft a python solution that loops over
vertices of the road network, and submits requests to the NED point
elevation lookup. This would obviously be very slow, and possibly
memory-bound--- therefor you would need to chunk the operation,
possibly by county.
Do you really need the precision of the 1/3 arc second data? You do
realize that this is possibly a multi-terabyte data set?
Cheers,
Dylan
On Wed, Aug 18, 2010 at 6:38 PM, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> Hi all,
> I plan to download the USGS NED 1/3 arcsec dataset and I noticed it is
> available in 2 formats: ArcGrid and GridFloat
> Is one easier, faster, smaller, etc to work with than the other?
> My goal is to augment the Tiger road network with Z elevation data.
> I'm wondering if there is a tool that already does this, like read a
> shapefile, augment with elevation and write a new shapefile. Or if I would
> need to write a tools that does that. Can postgis be used to do this?
> Given a lat,lon, what is the fastest way to get the elevation?
> Thank you for any input you can provide.
> -Steve
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
