[gdal-dev] Re: Creating new mosaic overview
christian.mueller at nvoe.at christian.mueller at nvoe.at
Thu Aug 19 09:33:28 EDT 2010
Look here, http://www.gdal.org/gdal_retile.html
I think this should do your job.
Cheers
Quoting "Edi.Karadumi" <edikaradumi at gmail.com>:
> Yep but im creating an overview so i need a lowered resolution so i need the
> -ps parameter. I know that gdal_merge.py can take more than two files but
> the new mosaiced overview will have 6000 or less tiles, thats why i said
> that i dont want to write the command for every two tiles.
> Best Regards
> Edi Karadumi
> Edi,
> You don't have to specify the -ps parameter. You specify it only if you want
> to set a specific resolution. Also, note that gdal_merge.py can accept more
> than two files.
> Another way to do what you are probably trying to do is to build a VRT
> file[1] using gdalbuildvrt [2] and then build an external overview using
> "gdaladdo -ro" specifying the level of overview.
> On Thu, Aug 19, 2010 at 5:59 PM, Edi.Karadumi <[hidden email]> wrote:
> i have 3T of images and there are more than 12000 tiles. I want to create a
> new mosaic overview. Im using the gdal_merge.py command. I cant use
> gdal_merge for every 2 images. Is there any other way to merge the tiles for
> the new layer? if my pixel size of the original tile are 0.08meters, how
> many should be the size of the pixel of the merged tiles? I mean what pixel
> size should i use in the gdal_merge.py ... -ps parameter?
> Chaitanya kumar CH wrote:
>> Edi,
>> want
>> more
>> than two files.
>> On Thu, Aug 19, 2010 at 5:59 PM, Edi.Karadumi <edikaradumi at gmail.com>
>>> a
>>> for
>>> pixel
>>> View this message in context:
>>> http://osgeo-org.1803224.n2.nabble.com/Creating-new-mosaic-overview-tp5439991p5439991.html
>>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Best regards,
>> Chaitanya kumar CH.
>> /tʃaɪθənjə/ /kʊmɑr/
>> +91-9494447584
>> 17.2416N 80.1426E
> Edi,
> than two files.
> On Thu, Aug 19, 2010 at 5:59 PM, Edi.Karadumi <edikaradumi at gmail.com> wrote:
>> a
>> for
>> pixel
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
> Edi,
> than two files.
>> a
>> for
>> pixel
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
> http://osgeo-org.1803224.n2.nabble.com/Creating-new-mosaic-overview-tp5439991p5440218.html
This message was sent using IMP, the Internet Messaging Program.
