[gdal-dev] Create copy without any bands
Tim Keitt tkeitt at gmail.com
Sat Aug 21 13:14:14 EDT 2010
OK. I found the source. Yes, that is fairly straightforward to copy and modify.
It seems making a copy without propagating the raster bands would be
very common operation. Would it make sense to introduce a new function
to GDAL? ShallowCopy?
THK
On Sat, Aug 21, 2010 at 7:05 PM, Tim Keitt <tkeitt at gmail.com> wrote:
> I noticed DefaultCreateCopy, but appears not to be documented. At
> least there is no click through link in the class reference. What does
> it do? How is it modified? In the driver code?
> THK
> On Sat, Aug 21, 2010 at 7:00 PM, Chaitanya kumar CH
> <chaitanya.ch at gmail.com> wrote:
>> Tim,
>> You can create it easily by modifying GDALDriver::DefaultCreateCopy()
>> On Sat, Aug 21, 2010 at 9:51 PM, Tim Keitt <tkeitt at gmail.com> wrote:
>>> I am writing a utility that takes a raster as input and outputs a
>>> raster with all attributes the same, except that I only want one
>>> output band and I want to specify its type independent of the data
>>> type in the input file. Is there a function that creates a copy of a
>>> dataset (or creates a virtual dataset), but does not copy any raster
>>> bands? This would really simplify things as all I would have to do is
>>> add a band to the output dataset of the desired type.
>>> THK
>>> Timothy H. Keitt
>>> http://www.keittlab.org/
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Best regards,
>> Chaitanya kumar CH.
>> /tʃaɪθənjə/ /kʊmɑr/
>> +91-9494447584
>> 17.2416N 80.1426E
> Timothy H. Keitt
Timothy H. Keitt
