[gdal-dev] Create copy without any bands
Tim Keitt tkeitt at gmail.com
Sat Aug 21 19:21:39 EDT 2010
On Sat, Aug 21, 2010 at 7:41 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Tim Keitt wrote:
>> How about:
> Tim,
> I don't really like!  I think instead it would be better to have
> a method/function to copy a variety of types of metadata - possibly
> taking some flags to control what should be copied.  Perhaps something
> that works similar to the GDALPamDataset::CloneInfo() and
> GDALPamRasterBand::CloneInfo() methods?
> There is value in a helper to copy the various sorts of metadata
> (including georeferencing, color tables, etc) but there are also a
> wide variety of situations for use and it is hard to make something
> that serves most or all of them.  I have, till now, tried to avoid
> baking anything into the standard api for this because I couldn't
> really wrap my head around a sufficiently general, yet not too complicated
> arrangement.
> BTW, why did you ignore GCPs, and RPCs in your ShallowCopy() suggestion?
Because I've never had the opportunity to use them. Also because these
are not in DefaultCreateCopy which I took and simply deleted the part
that copies the raster bands.
There are a vast number of raster-to-raster operations that simply
need a dataset to store the output. The things that are almost always
different are the file format (only for user convenience) and the data
type of the resulting raster band.
BTW, my choice of "ShallowCopy" is probably not a good name as it
implies a view containing pointers to the original data. Perhaps
"PrepareOutput" would be better.
THK
> Best regards,
>> /*                         ShallowCopy()                                */
>> GDALDataset *GDALDriver::ShallowCopy( const char * pszFilename,
>>                                      GDALDataset * poSrcDS,
>>                                      GDALDataType etype, int nBands,
>>                                      int bStrict, char ** papszOptions,
>>                                      GDALProgressFunc pfnProgress )
>>    if( pfnProgress == NULL )
>>        pfnProgress = GDALDummyProgress;
>> /*      Create destination dataset.                                     */
>>    GDALDataset  *poDstDS;
>>    int          nXSize = poSrcDS->GetRasterXSize();
>>    int          nYSize = poSrcDS->GetRasterYSize();
>>    CPLErr       eErr;
>>    CPLDebug( "GDAL", "Using default GDALDriver::CreateCopy
>> implementation." );
>>    if( !pfnProgress( 0.0, NULL, pProgressData ) )
>>        CPLError( CE_Failure, CPLE_UserInterrupt, "User terminated" );
>>        return NULL;
>>    poDstDS = Create( pszFilename, nXSize, nYSize, nBands, eType,
>> papszOptions );
>>    if( poDstDS == NULL )
>>        return NULL;
>> /*      Try setting the projection and geotransform if it seems         */
>> /*      suitable.  For now we don't try and copy GCPs, though I         */
>> /*      suppose we should. Also copy metadata.                          */
>>    double      adfGeoTransform[6];
>>    if( poSrcDS->GetGeoTransform( adfGeoTransform ) == CE_None
>>        && (adfGeoTransform[0] != 0.0
>>            || adfGeoTransform[1] != 1.0
>>            || adfGeoTransform[2] != 0.0
>>            || adfGeoTransform[3] != 0.0
>>            || adfGeoTransform[4] != 0.0
>>            || adfGeoTransform[5] != 1.0) )
>>        poDstDS->SetGeoTransform( adfGeoTransform );
>>    if( poSrcDS->GetProjectionRef() != NULL
>>        && strlen(poSrcDS->GetProjectionRef()) > 0 )
>>        poDstDS->SetProjection( poSrcDS->GetProjectionRef() );
>>    poDstDS->SetMetadata( poSrcDS->GetMetadata() );
>>    return poDstDS;
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
Timothy H. Keitt
http://www.keittlab.org/
