[gdal-dev] Working with NED elevation data - part 2
Stephen Woodbridge woodbri at swoodbridge.com
Sun Aug 22 23:28:17 EDT 2010
Even,
It seems the adding:
#include <cpl_conv.h>
resolves the segv issue.
I would recommend changing the example in:
http://www.gdal.org/gdal_tutorial.html
To include that in the section "Reading Raster Data" because the example
C code uses CPLMalloc(). It would also be very helpful to add:
CPLFree(pafScanline);
to the example code. And a link to http://gdal.org/cpl__conv_8h.html
which is not otherwise referenced.
Anyway, code is working great now. I am generating an elevation profile
from a number of points along a path.
1. tried to get the points via USGS NED webservice: 132 point took 4-6
min and 132 points is a short path.
So I downloaded the USGS NED data and created a .vrt file for the layer:
2. C code to open vrt file and handle requests via local CGI took 4 sec
3. C code to open vrt file and handle requests via local FCGI took < 1 sec
And each profile time above has some overhead because it has to compute
a route in pgrouting to get the points needed to generate the profile.
http://imaptools.com:8080/routeloops/route_loops6.php?x=-71.387764&y=42.620002&length=4828.032&heading=-1&shape=-1&rand=0.06593320066404917&allow=0%2C1&zoom=11&lat=42.62&lon=-71.38776&layers=B00TT&ll=-71.387764%2042.620002&len=3&rs=0.4646901273751023&al=0,1&u=E&cw=1&f=profile
Thanks for the help and support everyone.
-Steve
On 8/22/2010 12:43 PM, Even Rouault wrote:
> Stephen,
> at first sight, I don't see anything wrong with your code.
> You need to include "cpl_conv.h" for CPLMalloc(). And memory allocated with
> CPLMalloc() should be freed with CPLFree().  The doc is there :
> http://gdal.org/cpl__conv_8h.html  (http://gdal.org/ ->  API reference
> documentation ->  Files ->  cpl_conv.h )
> But that doesn't likely account for the segmentation fault you have. This code
> should work just fine with a GTiff or VRT dataset.
> Do you use a recent version of GDAL ? If not, retry ;-) If still crashing,
> could you attach a debugger and show the stack trace at the place where it
> crashes and/or run valgrind on it ?
> Best regards,
> Even
> Le dimanche 22 août 2010 05:23:45, Stephen Woodbridge a écrit :
>> OK, well may to answer my own question by reading the GDAL API Tutorial
>> and taking a guess at some parts I came up with the following. This is
>> basically just a copy of the tutorial and at the end I added some code
>> that I'm hoping reads the correct pixel for my lat,lon and prints out
>> the elevation.
>> The tutorial code for "Fetching a Raster Band" works on a GTiff file but
>> segv on a VRT file. Not sure why this happened, although there was a
>> compiler warning about:
>> testit.c: In function 'main':
>> testit.c:80: warning: cast to pointer from integer of different size
>> which would be:
>>       float *pafScanline;
>>       pafScanline = (float *) CPLMalloc(sizeof(float)*nXSize);
>> I could not find docs on CPLMalloc, or any info on if I need to free
>> that and how!
>> I would appreciate if someone could code review the code at the end and
>> comment on whether or not this is correct.
>> Thanks,
>>     -Steve
>> #include<gdal.h>
>> int main() {
>>       GDALDatasetH  hDataset;
>>       char *pszFilename = "/u/srcdata/ned2.vrt";
>>       //char *pszFilename = "/u/srcdata/NED2/-90_28_-84_30.tif";
>>       GDALDriverH   hDriver;
>>       double        adfGeoTransform[6];
>>       GDALRasterBandH hBand;
>>       int             nBlockXSize, nBlockYSize;
>>       int             bGotMin, bGotMax;
>>       double          adfMinMax[2];
>>       float *pafScanline;
>>       int   nXSize;
>>       int nXOff, nYOff;
>>       float elevation;
>>       float lon = -74.0;
>>       float lat =  42.0;
>>       GDALAllRegister();
>>       hDataset = GDALOpen( pszFilename, GA_ReadOnly );
>>       if( hDataset == NULL ) {
>>           printf("Failed to open %s!\n", pszFilename);
>>           exit(1);
>>       hDriver = GDALGetDatasetDriver( hDataset );
>>       printf( "Driver: %s/%s\n",
>>           GDALGetDriverShortName( hDriver ),
>>           GDALGetDriverLongName( hDriver ) );
>>       printf( "Size is %dx%dx%d\n",
>>           GDALGetRasterXSize( hDataset ),
>>           GDALGetRasterYSize( hDataset ),
>>           GDALGetRasterCount( hDataset ) );
>>       if( GDALGetProjectionRef( hDataset ) != NULL )
>>           printf( "Projection is `%s'\n", GDALGetProjectionRef( hDataset )
>>       if( GDALGetGeoTransform( hDataset, adfGeoTransform ) == CE_None )
>>           printf( "Origin = (%.6f,%.6f)\n",
>>           adfGeoTransform[0], adfGeoTransform[3] );
>>           printf( "Pixel Size = (%.6f,%.6f)\n",
>>               adfGeoTransform[1], adfGeoTransform[5] );
>>       hBand = GDALGetRasterBand( hDataset, 1 );
>>       GDALGetBlockSize( hBand,&nBlockXSize,&nBlockYSize );
>>       printf( "Block=%dx%d Type=%s, ColorInterp=%s\n",
>>           nBlockXSize, nBlockYSize,
>>           GDALGetDataTypeName(GDALGetRasterDataType(hBand)),
>>           GDALGetColorInterpretationName(
>>               GDALGetRasterColorInterpretation(hBand)) );
>>       adfMinMax[0] = GDALGetRasterMinimum( hBand,&bGotMin );
>>       adfMinMax[1] = GDALGetRasterMaximum( hBand,&bGotMax );
>>       if( ! (bGotMin&&  bGotMax) )
>>           GDALComputeRasterMinMax( hBand, TRUE, adfMinMax );
>>       printf( "Min=%.3fd, Max=%.3f\n", adfMinMax[0], adfMinMax[1] );
>>       if( GDALGetOverviewCount(hBand)>  0 )
>>           printf( "Band has %d overviews.\n", GDALGetOverviewCount(hBand));
>>       if( GDALGetRasterColorTable( hBand ) != NULL )
>>           printf( "Band has a color table with %d entries.\n",
>>                    GDALGetColorEntryCount(
>>                        GDALGetRasterColorTable( hBand ) ) );
>>        * This section segv trying to do a memset in GDALRasterIO
>>        * if I use the VRT driver, but works OK on the GTiff file.
>>       nXSize = GDALGetRasterBandXSize( hBand );
>>       GDALRasterIO( hBand, GF_Read, 0, 0, nXSize, 1,
>>                     pafScanline, nXSize, 1, GDT_Float32,
>>                     0, 0 );
>>       /* convert the lon, lat in a pixel location on the file and
>>        * read that location into a float.
>>       nXOff = (lon - adfGeoTransform[0]) / adfGeoTransform[1] + 0.5;
>>       nYOff = (lat - adfGeoTransform[3]) / adfGeoTransform[5] + 0.5;
>>       GDALRasterIO( hBand, GF_Read, nXOff, nYOff, 1, 1,
>>                     &elevation, 1, 1, GDT_Float32,
>>                     0, 0 );
>>       printf("Elevation at %.6f, %.6f = %.1f\n", lon, lat, elevation);
>>       GDALClose(hDataset);
>>       return(0);
>> On 8/21/2010 6:07 PM, Stephen Woodbridge wrote:
>>> So I have been able to download the NED data and I have US coverage.
>>> The data is in GeoTiff and all in a single band Int16 format.
>>> I have create a ned.vrt file.
>>> So I'm interested in writing a simple program in C that I can pass a
>>> lat, lon and get the elevation. I assume I need to open the .vrt file
>>> but looking at the GDAL API, I'm not sure how to map the lat, lon to a
>>> pixel and then how to fetch the pixel value. If it matter, I will
>>> probably extend this later to process a list of locations or maybe
>>> extend it to read a shapefile and process the shape through it.
>>> Does anyone have a sample program that does something like this.
>>> -Steve
>>> woodbri at mappy:/u/srcdata$ gdalinfo -stats ned2.vrt
>>> Driver: VRT/Virtual Raster
>>> Files: ned2.vrt
>>> NED2/-100_25_-96_28.tif
>>> NED2/-102_28_-96_30.tif
>>> NED2/-102_30_-96_32.tif
>>> NED2/-102_32_-96_34.tif
>>> NED2/-102_34_-96_36.tif
>>> NED2/-102_36_-96_38.tif
>>> NED2/-102_38_-96_40.tif
>>> NED2/-102_40_-96_42.tif
>>> NED2/-102_42_-96_44.tif
>>> NED2/-102_44_-96_46.tif
>>> NED2/-102_46_-96_48.tif
>>> NED2/-102_48_-96_50.tif
>>> NED2/-108_28_-102_30.tif
>>> NED2/-108_30_-102_32.tif
>>> NED2/-108_32_-102_34.tif
>>> NED2/-108_34_-102_36.tif
>>> NED2/-108_36_-102_38.tif
>>> NED2/-108_38_-102_40.tif
>>> NED2/-108_40_-102_42.tif
>>> NED2/-108_42_-102_44.tif
>>> NED2/-108_44_-102_46.tif
>>> NED2/-108_46_-102_48.tif
>>> NED2/-108_48_-102_50.tif
>>> NED2/-114_30_-108_32.tif
>>> NED2/-114_32_-108_34.tif
>>> NED2/-114_34_-108_36.tif
>>> NED2/-114_36_-108_38.tif
>>> NED2/-114_38_-108_40.tif
>>> NED2/-114_40_-108_42.tif
>>> NED2/-114_42_-108_44.tif
>>> NED2/-114_44_-108_46.tif
>>> NED2/-114_46_-108_48.tif
>>> NED2/-114_48_-108_50.tif
>>> NED2/-120_32_-114_34.tif
>>> NED2/-120_34_-114_36.tif
>>> NED2/-120_36_-114_38.tif
>>> NED2/-120_38_-114_40.tif
>>> NED2/-120_40_-114_42.tif
>>> NED2/-120_42_-114_44.tif
>>> NED2/-120_44_-114_46.tif
>>> NED2/-120_46_-114_48.tif
>>> NED2/-120_48_-114_50.tif
>>> NED2/-123_33_-120_37.tif
>>> NED2/-125_37_-120_39.tif
>>> NED2/-125_39_-120_42.tif
>>> NED2/-126_42_-120_44.tif
>>> NED2/-126_44_-120_46.tif
>>> NED2/-126_46_-120_48.tif
>>> NED2/-126_48_-120_50.tif
>>> NED2/133_6.5_138.5_10.tif
>>> NED2/-139.0019842_51.9997277_-127.0018384_58.9998127.tif
>>> NED2/-139.0024054_58.9997472_-127.0018101_66.0000944.tif
>>> NED2/144_13_146_16.tif
>>> NED2/151_5_163.5_8.tif
>>> NED2/-157_18_-152_23.tif
>>> NED2/-157.5_18.75_-154.5_21.5.tif
>>> NED2/-160.5_21_-157.5_22.5.tif
>>> NED2/-162_18_-157_23.tif
>>> NED2/-171_-14.5_-169_-14.tif
>>> NED2/-68_17_-64_18.tif
>>> NED2/-72.0002778_40.9999994_-67.9999992_44.tif
>>> NED2/-72.0002778_44_-66_46.tif
>>> NED2/-72.0002778_46_-66_48.tif
>>> NED2/-78.0002778_33.0000047_-75.0000047_36.tif
>>> NED2/-78.0002778_36_-72_38.tif
>>> NED2/-78.0002778_38_-72_40.tif
>>> NED2/-78.0002778_40_-72_42.tif
>>> NED2/-78.0002778_42_-72_44.tif
>>> NED2/-78.0002778_44_-72_46.tif
>>> NED2/-84.0002778_24_-78_26.tif
>>> NED2/-84.0002778_26_-78_28.tif
>>> NED2/-84.0002778_28_-78_30.tif
>>> NED2/-84.0002778_30_-78_32.tif
>>> NED2/-84.0002778_32_-78_34.tif
>>> NED2/-84.0002778_34_-78_36.tif
>>> NED2/-84.0002778_36_-78_38.tif
>>> NED2/-84.0002778_38_-78_40.tif
>>> NED2/-84.0002778_40_-78_42.tif
>>> NED2/-84.0002778_42_-78_44.tif
>>> NED2/-85.0002778_44.0000047_-82.0000047_47.tif
>>> NED2/-90_30_-84_32.tif
>>> NED2/-90_32_-84_34.tif
>>> NED2/-90_34_-84_36.tif
>>> NED2/-90_36_-84_38.tif
>>> NED2/-90_38_-84_40.tif
>>> NED2/-90_40_-84_42.tif
>>> NED2/-90_42_-84_44.tif
>>> NED2/-90_44_-85_46.tif
>>> NED2/-90_46_-85_49.tif
>>> NED2/-96_28_-90_30.tif
>>> NED2/-96_30_-90_32.tif
>>> NED2/-96_32_-90_34.tif
>>> NED2/-96_34_-90_36.tif
>>> NED2/-96_36_-90_38.tif
>>> NED2/-96_38_-90_40.tif
>>> NED2/-96_40_-90_42.tif
>>> NED2/-96_42_-90_44.tif
>>> NED2/-96_44_-90_46.tif
>>> NED2/-96_46_-90_48.tif
>>> NED2/-96_48_-90_50.tif
>>> Size is 1180816, 284173
>>> Coordinate System is:
>>> GEOGCS["WGS 84",
>>> DATUM["WGS_1984",
>>> SPHEROID["WGS 84",6378137,298.257223563,
>>> AUTHORITY["EPSG","7030"]],
>>> AUTHORITY["EPSG","6326"]],
>>> PRIMEM["Greenwich",0],
>>> UNIT["degree",0.0174532925199433],
>>> AUTHORITY["EPSG","4326"]]
>>> Origin = (-171.000000000113090,66.000094447240443)
>>> Pixel Size = (0.000283278659440,-0.000283278659440)
>>> Corner Coordinates:
>>> Upper Left (-171.0000000, 66.0000944) (171d 0'0.00"W, 66d 0'0.34"N)
>>> Lower Left (-171.0000000, -14.5000520) (171d 0'0.00"W, 14d30'0.19"S)
>>> Upper Right ( 163.4999735, 66.0000944) (163d29'59.90"E, 66d 0'0.34"N)
>>> Lower Right ( 163.4999735, -14.5000520) (163d29'59.90"E, 14d30'0.19"S)
>>> Center ( -3.7500132, 25.7500212) ( 3d45'0.05"W, 25d45'0.08"N)
>>> Band 1 Block=128x128 Type=Int16, ColorInterp=Gray
>>> Minimum=-83.000, Maximum=4665.000, Mean=25.333, StdDev=189.129
>>> Metadata:
>>> STATISTICS_MINIMUM=-83
>>> STATISTICS_MAXIMUM=4665
>>> STATISTICS_MEAN=25.332848474484
>>> STATISTICS_STDDEV=189.12886049417
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
