[gdal-dev] Re: Artifacts when presenting WMS based on a number of adjoining vrt files with overviews
jonas nielsen jonasln at gmail.com
Mon Aug 23 16:57:45 EDT 2010
The original images that the overviews are built on are 10000 by 10000
pixels.
And yes, the artifacts appear without reprojection.
-Jonas
On Mon, Aug 23, 2010 at 6:24 PM, Jukka Rahkonen
<jukka.rahkonen at mmmtike.fi>wrote:
> jonas nielsen <jonasln <at> gmail.com> writes:
> > Help would
> > be sincerely appreciated:
> > We are
> > seeing artifacts when presenting WMS images based on a number of
> adjoining .vrt
> > files with overviews.
> Hi,
> What are the dimensions in pixels of the original images with 10 cm pixel
> size?
> Is it right that you are seeing artifacts even if you do not reproject the
> layer
> for output?
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100823/322f37a6/attachment-0001.html
