[gdal-dev] Integer error in creating bigtiff image
Doug_Newcomb at fws.gov Doug_Newcomb at fws.gov
Tue Aug 24 15:05:08 EDT 2010
Hi folks,
I'm working with someone trying to merge and reproject 1108 4 band tiff
images into 1 BIGTIFF image.  The command line options are as follows:
 gdalwarp -s_srs EPSG:26918 -t_srs EPSG:32119 -wo 'SOURCE_EXTRA=3' -wo
 'SKIP_NOSOURCE=YES' -wm 4000 --config 'GDAL_CACHEMAX=2000' -tps -rcs
 -srcnodata '0' -of GTIFF -co 'BIGTIFF=YES' -co 'TFW=YES' -tr 1 1
 /work/lisa/utm18/*.tif
 /work/lisa/reprojected_and_merged/naip_utm18_32119.tif
The process stops with the following error:
ERROR 1: Integer overflow : nDstXSize=29400, nDstYSize=19377
The command worked fine with 33 tiff images.  The individual is using gdal
1.7.2 on 64 bit linux.
Googling a bit and grepping the source code makes me think the problem is
in reading the a tiff file, perhaps a badly formatted input tiff image?
I suggested that the user try smaller chunks based on latitude rather than
the whole utem zone for the state.
Thoughts?
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
The opinions I express are my own and are not representative of the
official policy of the U.S.Fish and Wildlife Service or Dept. of the
Interior.   Life is too short for undocumented, proprietary data formats.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100824/c7121746/attachment.html
