[gdal-dev] nonspatial column with ogr.
ahmet temiz ahmettemiz88 at gmail.com
Sat Aug 28 12:52:24 EDT 2010
thank you
I think I need one more clarification. Doesn't "field" have same
meaning with column ?
or what does "field" correspond to in sql jargon ?
I will appreciate if you make me clear
2010/8/24 Frank Warmerdam <warmerdam at pobox.com>:
> ahmet temiz wrote:
>> hello
>> I can create spatial column. But I don't know how I can create
>> nonspatial column with ogr in gdal-java.
>> something like column "name" and its value "xxxx"
> Ahmet,
> I believe you are looking for the CreateField() method on the OGR Layer
> class.  Note that it does not provide a mechanism to populate the new
> column with a particular value for pre-existing features.
> http://www.gdal.org/java/org/gdal/ogr/Layer.html#CreateField%28org.gdal.ogr.FieldDefn,%20int%29
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
